How to program Slots into BCD 536HP
mciupa
Moderator
I've moved this question to Tech Support for a quicker response. :)
D
DaveNF2G
Guest
You should only see slot settings for DMR conventional, as in trunked systems a talkgroup can usually occupy either slot depending on system loading.
gary123
If you are entering it in as a conventional freq and selecting DMR then you can only enter in the color code. I have recently found that many DMR systems simplex or repeatered have a TG (talk group). to recieve these systems properly you will need to create a one freq trunked system even though the channel is not trunked. This will let you create a department and enter in both the TG and the timeslot.
The TG can be located by using the trunked discovery mode.
krazzedkanuk
Kingsville, ON.
Would it be possible for you to post a couple screen shots of what you are talking about?
thanks
