Thanks. So the only difference between Tier I and II is one is simplex and the other is a repeater?
That's what I recall from the docs.
So if it has RAS, what's to stop me from programming a portable DMR radio for receive only just to listen? How will they know my radio even exists?
Your radio will not know how to properly compute the checksums on the link control messages, so your radio will not know which talkgroups are in use. You can tell the radio to monitor group 123, but the radio will never know when they talk.
A lot of the time, I'll see DSD+ scrolling like mad but no one is actually keyed up and talking. Why? Do these DMR systems transmit data like text messages or image files too?
On control/rest channels, it's just the same system status messages over and over. On a non-control/rest channel, it's usually just idle messages.
Here's what I'm seeing in the Even Log. It only shows "Ch=1" or "Ch=2" but no slot number.
Hm. Looks like when you're monitoring a control or rest channel, DSD+ displays channel numbers (ch 1/2 = first/second slot on first RF channel, ch 3/4 = first/second slot on second RF channel, etc.), but when you're monitoring a traffic channel, DSD+ displays slot 1 and slot 2.
Is there an easy to way to copy and paste the rows of data into a form post?
Data from the event log? Sure, just edit the log file with Notepad and use copy/paste.
What do the abbreviations "CSBK" and "TLC" mean that keep scrolling real fast? Other times it just says "Idle". And also, what does "BS DATA" mean?
Control Signaling Block - typically control channel messages related to registrations, affiliations, system status/features, neighbor lists, traffic channel grants, short data messages, ...
Terminator with Link Control - a voice call (typically) just ended; now would be a good time for anyone who wants to reply to key up; otherwise, the hang timer will expire and some other group will get a shot at using the channel.
BS DATA - the repeater is sending (or repeating) some kind of data. Could be AVL or text messaging, or who knows what.
Do Tier 3 systems have a dedicated control channel.
Yes.
and how can you tell if that's what you're listing to?
DSD+ will display
TIII at the bottom of the event window.
I found a frequency that is giving some extra information about sites and neighbors and this and that. Wondering what all this means. What's that part at the bottom that says "NL: 4 9 14"?
That's site 6's neighbor list.
And how do you interpret the site numbers. Does 115-6 mean the System ID is 115 and there are at least 6 different repeater sites?
The network ID is 115 and you're monitoring site number 6's control channel.
