How to trunk on a Pro97? (having trouble)
kc8qln
Using a Pro97 Scanner & Win97 software-
I prgrammed in the frequencies in order.
I programmed in about 8 good talk ID's (in Decimal)
Changed the Type to MOT
Hit Upload to Scanner.
I go to Bank 4 manually (where I stored them). Pressed MAN -> 400 -> MAN
In manual mode, I HEAR activity on channel 400, so I know it's active.
I hit FUNC -> TRUNK, and it shows me a trunking screen that has no activity.
It says
ID BANK 4-3 ON
Motorola TDIG#03 (hitting the arrows keys changes the TGID)
MOT: None
But there is no activity. How can I get some scanning or activity?
DaveIN
Founders Curmudgen
West Michigan
It says
ID BANK 4-3 ON
MOT: None
All you need to do is set the trunking mode in Func + Trunk, i.e Mot for Motorola. If you have a Motorola control channel proogrammed into a bank make sure that channel is set to MOT by pressing MAN -> 400 -> MAN, then the Mode button until you see MOT with the frequency on the display, then press Scan to start tracking. If a talkgroup becomes active it will stop, display the talkgroup number or alpha-tag if you programmed with Win97 and the VC = Voice Channel.
seamusg
Grand Blanc, MI
It says
ID BANK 4-3 ON
MOT: None
What system are you trying to program in?
