How to wire a magnet mount
GatorMan96
I have what i believe is a hustler magnet mount that coax cable was ripped out. I bought a new coax cable but im not sure how to wire it up and i cannot find anything on how its wired under the magnet. It has one single stud in the middle that doesnt look to have any spacer. It looks like one single bolt that you run the magnet over to bolt down. There are two nylon spacers on the bolt but how does it wire up? It seems to me like the spacers would be useless if the bolt is solid and has no center or outer connections. Please help me figure out how to wire this thing up. Thank you.
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Welcome to the RR forums. You'd be off buying a new unit, they're pretty cheap. I've tried a few times to "rewire" magmounts. The components inside the magmount are delicate and you'll likely break something else if you fumble with it too much
R8000
Very Low Battery
To add to this, weatherproofing homebrew mobile antennas is a challenge. Even if you did rewire it, sealing it up enough to prevent corrosion will be difficult.
I also vote to just bite the bullet and buy a new one from a name brand source like Larsen, Diamond, Comet, Laird. Avoid the cheap china knock offs that appear on Amazon for a super low price.
izzyj4
Ova here
Without seeing the antenna specifically, I would be taking a shot in the dark to explain re-wiring it. It is relatively easy, I did it with an old Radio Shack 3-section mag-mount. I use it for my attic antenna and works fairly well. I replaced the center bolt for the antenna element in the base and utilized two nuts on it. I crimped a ring connector to the center conductor of the RG-8 I used then placed the ring on the bolt between the two nuts. I then soldered the shielded braid to the magnet where the original wire was. Since I am using it inside, I soldered the RG-8 to a UHF female connector to it. When I get a chance I'll get a picture posted to show you what I did. Hopefully this will help you out a bit.
