howard co fire dispatch PL
whitesox4life
Grant Co, IN
Wirelessly posted (LGE-VX9100/1.0 UP.Browser/6.2.3.2 (GUI) MMP/2.0)
i just programmed howard county fire dispatch into a portable radio with the pl on the rx side as well (to eliminate bleedover) and when i monitor that channel, nothing is picked up. When i toggle the carrier squelch, i start picking up transmissions. Is the PL listed in the database incorrect?
jerk
jerkville
That would be my first guess... unless your programming was wrong.
Do you have a scanner that you can use to search for PL/DPL tones, I would start with that.
whitesox4life
Grant Co, IN
no PL capable scanner...hoping to get first hand info from someone in Howard Co
jerk
jerkville
Sorry I'm to far away... there is a guy that has a feed on here, not sure if he can monitor those frequencies or not.
dfoutch
Anderson, Indiana
Speaking of Howard Co Fire
App pending
Public Safety Pool, Conventional - 0004063907 - HOWARD, COUNTY OF
Add location: 625 S. BERKLEY KOKOMO, IN HOWARD County
Add freq: 154.31 FB(only) 11K2F3E
jerk
jerkville
App pending
There should be a lot more of those coming because of narrowbanding.
I know my County has been discussing it, but some radios can't do narrow and FD's can't afford new ones.
