Howard County Fairgrounds Hamshow
JackTV
Hey All,
Did anyone go to the Hamshow at howard County Fairgrounds?
I did.It was ok but it was not as good as Timonium.I got a good deal on some
LMR-500 cable...135ft with N connectors installed $30.I just hooked it up
to the LPA and it DID make a difference.Helped the 800mhz signal and yes
it did help UHF air.It is an improvement over LMR-400
Able to pick up BWI a little stronger on UHF & VHF.
Jack
baybum
Howard County
Ditto to the ditto above.
Maybe we need a "calendar of events sticky" on the Md. forum.
Not easy keeping up on everything.
