HP-1 AND DSD SOFTWARE?
se
Minto, New Brunswick Canada
Hello All.
Can anybody in the forum tell me if the DSD Software will work with the HP-1, and if so will it decode the new Mototrbo system in the Middlesex database?
Thanks Sheldon.
Forts
Ontario, Canada
No it will not. From what I understand the HP-1 does not have a useable discriminator output, or a point inside that can be tapped. If you are wishing to use DSDPlus your best bet would be to get ahold of a cheap analog scanner that you could have a tap installed in.
Forts
Ontario, Canada
Sorry, I don't. I wouldn't be surprised to see more commercial users move to MotoTRBO or NXDN.... Maybe even some of the hospitals, but this day and age who knows if they have any budget for that.
As far as everyone else goes, no changes that I'm aware of I've heard rumblings that some changes are coming for Elgin County however... Sounds like county fire and roads/works departments are all going MotoTRBO.
