Yep, but don't feel bad, as I took me a long while to get it. With the range set at 0 it is only going to look for systems whose range fall directly onto where you are with the HP1. By setting to 5 miles you have now asked it to go out and look for systems that are even further away. But these aren't five miles away...they may have been given a system range of 50 miles, so if you are 52 miles from the transmiiter and set on 5 it is going to scan them. With the range set on 0, it will not load them into what you can hear. Set it at 0 and you will scan fewer systems. It is not like the 996 where you told the scanner, I want to hear this system and that system, when I am within ??? range. I am afraid I am not giving you a great explanation.
Imagine you are driving down a highway, and the scanner of course know where you are. Around you on your route as dozens of radio systems. Small towns may have a range of 5 miles, cities 20 miles, counties 40 miles, and for statewide systems several hundred miles...as you move, you pass in and out of systems. If range is 0 then the HP1 only scans the ones you directly drive thru...if you set it for 5 or even more, it goes out and says, there is the edge of a aystem 4 miles away, I should include that one.
That said, this whole concept is such a radical new idea, it has to be looked at differently. The DB is tagged with the lat/lon of each system, and an estimate of range attached. Sometimes it is too much, sometimes not enuf. As time goes on, the DB will improve and range of the systems get more precise. You may be hearing the other areas, because the range is not set right on the entry. In that case, you can contact the DB administrator for your area and ask them to correct it.
I have used mine many times mobile, and at least in my area it works great...just a seamless move from systems as I drive out of the range of one and into another. Yea, I wanted to scream at the radio because I kept hearing the bus system police way out of town. But then realized they cover the routes into the suburbs, so the range is greater than just downtown. I eventually just made it an avoid. One of the reasons I do not use an external antenna. It will not reach out for distant systems, so don't need the antenna to be able to hear great distances.
Hope this helps....
There is a another good explanation on the
www.homepatrol. com site under the blogs, titled Location...location...location...
