HP-1 and TGID patching
SDavis90
Middle Tennessee
If an analog type II trunk system patches 2 channels together (simulcast) to put two seperate departments (talk groups)on same channel during an incident such as when the display channel bar shows TGID: 123 456 for example - how do you program that to put a name to it?
I entered the first number already as a new talkgroup....I would like to label it as "simulcast" or something to that effect and assign an alert beep to it.
In this case the first number shows up 'only' during the patching together of the channels (departments), and the second number is an actual talk group (department) I already have programmed.
Of course, it rarely ever comes up, so I haven't had the opportunity to try it out.
VE3RADIO
Planet Earth
Turn off ID search or lockout the patch group, your XT series radio will pickup the transmissions on either of the two patched talkgroups.
