HP-1, Kenwood D710A, and Geosat 6
KC9AXZ
Sheboygan, WI
I have a HP-1 on order, It isn't here yet. I'm attempting to plan ahead. The HP-1 is mainly going to be used in the truck. I already have a GeoSat 6 GPS and a Kenwood D710A setup for APRS. Has anyone used this GPS and split to feed multiple radios? I'd like to use the single GeoSat GPS to feed the HP-1 and Kenwood radio. I also have a Delorme puck style GPS, but would like to not add another GPS to the truck just to run a scanner.
Jon
AK9R
Staff member
Super Moderator
Central Indiana
I had an AvMap G6 APRS that I used few times with my TM-D710. I eventually sold the G6, though. AvMap sticks it to you for map updates and loading the updates takes an inordinately long time. I also didn't care for the user interface. AvMap could learn a few things from Garmin. With a Garmin nuvi GPS receiver and an Argent Data GTRANS adapter, you get almost the same functionality as the AvMap G6 for a lot less money.
As for splitting the GPS signal, that's easy. Just build a splitter for the GPS-to-radio signal line. Most GPS receivers can drive two different destination devices. In my vehicle, I have a puck-type GPS receiver that drives both my TM-D710 and a RS-232 to USB adapter so I can get GPS data into a computer.
Paulsan
York PA
Does the Argent cable work with current generation Garmins? From reading the description, it appears to only work with older, discontinued Garmin products.
JASII
Memory Capacity
HP-1, Kenwood D710A, And Geosat 6
No, it works with the ones listed below. I simply bought a used Garmin Nuvi 350 on eBay, the Argent Data cable, and I was good to go. I love having one GPS do double duty!
https://buy.garmin.com/en-US/US/prod1449.html
AK9R
Staff member
Super Moderator
Central Indiana
I'm using a Garmin nuvi 1450 with an Argent GTRANS2 cable to connect to my TM-D710. It works OK, but you sometimes have to refresh the map to see the received APRS beacons.
airems
Florida
Does anyone have a simple wire diagram for the GPS feed wire split? I'm using a Nuvi 350 with a Kenwood TM-D700. It would be nice to run the HP off the single GPS. I have the Argent cable. Thanks!
w0fg
Decorah, IA
I'm following this thread with interest. I have the HP-1/Argent DPS combo that I use in the XYL's car. In my Jeep, I have the Kenwood TM-D700 w/Garmin GPS18 puck for APRS, and the Nuvi 390 for navigation. I'd really like to be able to use one of those with the HP-1 for the infrequent times I might have the HP-1 on board. What would be the simplest route?
AK9R
Staff member
Super Moderator
Central Indiana
I can draw everything except the HP-1 end of the splitter. What are the pin-outs?
AK9R
Staff member
Super Moderator
Central Indiana
This is pretty simple. I snatched the Kenwood GPS cable wiring diagram from the Kenwood manual and added the HP-1 GPS plug diagram that Mancow provided.
Note that the GPS cable Kenwood provides with the TM-D700 and TM-D710 can be a bear to solder to. Argent Data has a cable that's easier to work with and it has a right angle connector which may be easier to deal with in a mobile installation.
https://www.argentdata.com/catalog/product_info.php?cPath=21&products_id=29
  • Kenwood GPS-Uniden HP-1 wiring.pdf
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
All that's needed from that point (for me at least) is a way to know which wire in the HP1 (/396/996/etc) GPS cable corresponds to those pins, and it's "game on".
I have a GreenLightLabs GPS-710, which fits in between the TM-D710A control head and the radio, inline on the RJ45 cable. Its GPS signal is passed to the TM-D710A control head via a small 2.5mm cable, and on the opposide side of the GPS widget is another 2.5mm output which could go to my HP, freeing up a 12V socket in my car and reducing cable clutter.
JASII
Memory Capacity
I picked up a Garmin 350 on eBay for $35 with all the original accessories.
I think you will like it. I am sure that you already know this, but once it arrives register it with Garmin, do the firmware updates, and consider springing for LifeTime maps. Also, 8 GB micro SD cards are cheap. You will need the SD adapter, but that is not a big deal, of course. I was pleasantly surprised when I bought mine used a year ago. It had never been connected to a computer, so when I registered with Garmin I was eligible for a new map! Oh, and they told me it had a one year warranty. I mentioned that I bought it used, but they said since it had never been registered that they covered it for one year!
KC9AXZ
Sheboygan, WI
Wow... I thought I had reply email notifications on. I guess not. Thanks for all the info. I plan on using this information to wire up a cable, hopefully later tonight. I must admit that I did like my Garmin Nuvi GPS I had before better than my AvMap. I think the Garmin was much better for searching businesses and addresses than the AvMap. I now find myself using my smartphone more often to "Google" places then place them in my AvMap.
Jon KC9AXZ
KC9AXZ
Sheboygan, WI
Thank for the help guys! I now have the GPS running on the HP-1. The only snag I ran into was setting the baud rate. I set the rate to 9600 and it truned right on.
Jon
