HP Scanner GPS Location Question
wise871
Florida
Someone refresh my memory. I built a favorites with multiple systems. Each department in the system has GPS location and radius. I also added a trunking system. I added the coordinates to each of the tower sites and added a radius to them .
The question I have is the Departments/Talkgroups on the trunk system. Can I leave the Lat/Long at 0.00'00'00 and the scanner will scan these Talkgroups or will it skip them since I have no info about there location.
jkahn
Very good looking Member
Silver Spring MD
When you download the favorites list with the trunked system to the radio, set LOCATION block unchecked and it will scan when & where ever you enable it.
JK :)
