Long time listening and following these posts...First Time posting however...If this post is in the wrong area, please redirect....and accept my apologies.
Here goes:
I have a HP T5720 ThinClient running xpe sp3. Currently, I am using Radio Feed successfully and streaming a feed. I would like to have the ability to broadcast multiple feeds from this thinclient, so I went out and purchased 3 usb soundcards (c-media). I am using 1 of these usb soundcards currently with my active feed with no issues. The thinclient recognized the usb soundcard, and it showed up as an option available on the Radio Feed software.
The problem I have is when I create a new folder with the Radio Feed files. I install another usb soundcard, and it gets recognized by the thinclient. I run a new instance of Radio Feed and the program comes up. But, the new soundcard does not come up as an available option. The same problem appears when I use Scannercast...the additional usb soundcard for the additional feed is not getting recognized by the programs.
I believe I have checked the correct areas of the xpe system-there are no conflicts shown in the device manager....however both soundcards are showing as "location 0". Could this be a conflict? -even though there are no confilcts shown in Device Manager? If this is the issue, how does one correct it in an xpe environment?
Here's another strange issue that I cannot figure out....If I stop the one occurrance of Radio Feed, exit out of the program, then restart it.....the same problem appears....the 1 usb sound card is not recognized by the software. So at this point I have to restart the thinclient (because I did not commit the changes), the system will reboot, and everything will be back to normal.
I fear that I made a change somewhere that I was not conscious of ! The thinclient is not showing an active soundcard installed, however I am able to hear default windows sounds....is it possible that I deleted a file -somewhere- that I was not aware of....then committed the changes....unable to go back ?
Could this be causing the problem with my inability to stream multiple feeds?
I looked at the HP website for Thinclients....in the hopes of finding something that I could re-install (or install) to correct this issue...to no avail.
Gentlemen, please help and point me in a direction here as I don't know what to do. At this point, if I have to do a reinstall of xpe on the thinclient then so be it....but I am looking for ANY options before that.
Regards,
Neil
KB2KRJ
Here goes:
Regards,
Neil
KB2KRJ
