HP1 Firmware Request Upman
#1
Hi Paul!
Can we have the latest firmware release for this model made so when you set the audio options filter and manual thresh hold in p25 decode they are not lost every time you turn the scanner off?
Its real annoying to have to go into the menu's and set the decode value each time the scanner is rebooted.
Tim
