HP1 installed in 2011 Hyundai Sonata
SignalSeeker
West Sacramento
Got my HP1 mounted up last weekend after it sitting on my seat for a month as I used it. I made a mount to attach to the Uniden bracket. It has an external antenna, line out to my car stereo and power. When I program it I just pull it out since it removes in about 10 seconds.
Let me know what you guys things.
Here is the mount I made. Cut a sheet of plastic into a strip, heated and bent.
HP1 in the dash.
More HP1 in the dash.
Mount in the car without the HP1.
And the antenna Trunk Lip mount, i have about 8 different antennas. This is just an uncut whip which works great for most things.
SignalSeeker
West Sacramento
Yes it sounds good. It is using the linout on the HP1 to the line in on the stereo. No engine noise and the audio sounds better than on the HP1 by itself.
Justin
ScanWI
MN & WI DB Admin
Wisconsin
I love the mount one of these days I would like to pick up a HP-1
Bubba1661
WV DB Admin
Charleston W.V.
Man that looks Great, I have that same car. I take my Pro-106 with me all the time. What kind of antenna is that?
ResQguy
Two questions:
1. Are you using GPS, and if so how did you get the cable to fit while sticking out the side of the HP1?
2. What connectors/cables did you use for the line out? (mono/stereo/etc)
SignalSeeker
West Sacramento
The antenna is just a generic cut it yourself black NMO, uncut.
I have used the GPS in the past playing with it, but not currently. I drive a lot for work but it is to the same areas, so I just switch favorites and listen to only the groups I want.
I will try and take a picture of my audio cable. It is a 1ft stereo 3.5mm on both sides. Then using a 2.5 to 3.5 stereo adaptor with a 45 degree or so on the 2.5 side, it is about 3 inches long. I may still do a custom cable about 10 inches total with a 90 degree 2.5 and a straight 3.5.
Justin
SignalSeeker
West Sacramento
Thank you guys for all the nice comments. I keep forgeting to take a picture of the small audio cable I use, will try and remember when I get home.
Justin
