HP1- Will not record after upgrade
Audiodave1
Chadds Ford, PA
Today I went to turn on recording for the day on freq's of interest from a favorite list and the full DB but record is greyed out.
HP1 Advanced
FW 2.01
dB ver 9/4/2011
The record function is greyed out for all services, databases and favorites list.
I am unable to find anything in the settings that I may have corupted.
This is for conventional or TRS systems. Holding on a group, agency or system does not "un-grey" record.
Anyone else??
Dave
Audiodave1
Chadds Ford, PA
I have never touched it physically so it is OEM. Did a DB wipe and re-upload but no joy. Scans fine other than the record function.
OCO
Central Michigan
Recording is disabled when the scanner thinks the batteries are low.. Perhaps you have a bad cell?? I realize that you may have had it on the power supply, but if a cell is bad, it may drag the charging/operating voltage down also..
Audiodave1
Chadds Ford, PA
Well that was it! No batteries inserted = No record function.
Sounds like a threshold needs to be changed in the software to allow recording under this condition.
Thank you CJDC,
Dave
OCO
Central Michigan
I suspect that Uniden wants to prevent data errors that could occur if a write operation was in process and the scanner lost power.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Definitely something to be added to the FAQ. This is a question that is liable to come up again. best regards..Mike
bonus1331
Hogansville, Ga
Yes, you will not be able to use the discovery modes without batteries inserted if you use the record option.
Couldn't figure out why the "start" button was grayed out when attemting to start a new discovery mode session.
UPMan
Uniden Representative
Arlington, TX
It is mentioned on pages 19 and 20 of the O/M. In bold, italic type.
Also on Page 25 under troubleshooting.
KD8HE
Beckley WV
it's a guy thing...first thing we do when we open the box is toss the manual!
phask
KZZV - SE Ohio
It's been explained, if you search, has to do with corrupting the sd card if it loses power during a write.
