Try formatting the card in a PC, then reinstall and clear user data and then update database and download any favorite lists.
iM confused put that micro sd card in the slot where i put sd cards I have a laptop the slot is way to bigTry formatting the card in a PC, then reinstall and clear user data and then update database and download any favorite lists.
OPPS I got install with adapter got oneiM confused put that micro sd card in the slot where i put sd cards I have a laptop the slot is way to big
-iM confused put that micro sd card in the slot where i put sd cards I have a laptop the slot is way to big
it still says error-
Use this utility to format the card (recommended by Uniden):
SD Memory Card Formatter for Windows Download - SD Association
SD Memory Card Formatter END USER LICENSE AGREEMENT NOTICE: BY DOWNLOADING, INSTALLING OR USING THE PRODUCT, THE ENTITY OR INDIVIDUAL ENTERING INTO THIS AGREEMENT AGREES TO BE BOUND BY THE FOLLOWING TERMS. IF YOU DO NOT AGREE WITH ANY OF THESE TERMS, DO NOT DOWNLOAD, INSTALL, OR USE THE PRODUCT...www.sdcard.org
Then use the "clear user data" utility in Sentinel to prepare the card for use in the scanner, then write your programming to the card.
If you have only formatted the card, the scanner will not recognize the card and still give you an error..... until you use the "clear user data" function in Sentinel. You need to do both steps.Well I have no clue what I did I formatted it still have the error Im lost
I did thatIf you have only formatted the card, the scanner will not recognize the card and still give you an error until you use the "clear user data" function in Sentinel. You need to do both steps.
When you use the clear user data function, check the box that says “display all drives”.Ok I went over what I did I updated hp2 like it said I had to format mircosd card didi that Now I get a message to reomove batterys for 1mn still get message I cleared user data now a window comes up with select hpmicrosd on top on bottom of window there is refresh info display all ok and clear the ok is not hilited now what do I do
i did thatWhen you use the clear user data function, check the box that says “display all drives”.
