jake01
How can I read the hpe files on my Window 10 PC from Sentinel, Import from hpe file (Favorite List) Can't find a program to read hpe files?
Thanks, I have SDS 100 Scanner. But I want to find a program, that is for Windows 10. that is for reading hpe files, and is not a scanner program . I use Sentinel BCDx36HPYou must use Sentinel for working with them.
Some of the actual favorite list files are human readable but those are HPD type files and can be opened and edited with a simple text editor but you need to be careful and maintain spacing and tabs and such as well as proper syntax otherwise the scanner won't be able to read or understand the file.
I thought the HPD files were encrypted to comply with Radio Reference DB rules but that appears to not be the case.Thanks, I have SDS 100 Scanner. But I want to find a program, that is for Windows 10. that is for reading hpe files, and is not a scanner program . I use Sentinel BCDx36HP
You read hpe files using Sentinel or Arc536 or ProScan or other programs that are compatible with win10 and the hpe format.
Hpd are older Uniden scanners like the HP1/2 and hpe are used by Unidens scanners that are sold today.
/Ubbe
Thanks, I have SDS 100 Scanner. But I want to find a program, that is for Windows 10. that is for reading hpe files, and is not a scanner program . I use Sentinel BCDx36HP. Maybe there isn't one I can put it in my WordPad, but I can't read it!You read hpe files using Sentinel or Arc536 or ProScan or other programs that are compatible with win10 and the hpe format.
/Ubbe
Ubbe, I just looked at all the files from a SDS200 and 536HP SD Card and there are no HPE files at all on the cards. Everything is HPD file extensions and are all human readable from what I could see.You read hpe files using Sentinel or Arc536 or ProScan or other programs that are compatible with win10 and the hpe format.
/Ubbe
/Ubbe
Where the heck are HPE files used? I know I looked at some with the .HPE extension earlier today and they were full of unreadable code.Look for the HPD files for the favorites lists on the SD card, those are readable with any text editor.
I think I just answered my own question. .HPE files appear to be those files created by Sentinel when you do an Export of one of your favorite list files.Where the heck are HPE files used? I know I looked at some with the .HPE extension earlier today and they were full of unreadable code.
I'm not sure but the HPE files may be encrypted to comply with Radio Reference DB rules.
I know the GRE versions of EZ-Scan will not let you edit any of the files downloaded as part of the RR database.
I doubt you will find anything that will work directly with the HPE files.
What is your reason for not using Sentinel?
You can view the HPE file contents all you want but the data will be meaningless. Open one with any text editor and you will see.
I'm also not so sure that ProScan actually reads and works with the HPE files. I think it works with the HPD files used by your favorites lists but I could be wrong about that.
I do use Sentinel and I like it, but I want to printout exactly what is in the favorites lists, with voids, that is in the scanner.I'm not sure but the HPE files may be encrypted to comply with Radio Reference DB rules.
I logged the entire contents of one of my hard drives and all the HPE files are favorite exports and are not human readable.
I just saw this as well. I guess I never really looked at the extensions Sentinel uses.Sentinel also stores your favorites lists on your computer hard drive in the HPD readable format.
ProScan can import hpd (Favorites) & hpe Files.I'm also not so sure that ProScan actually reads and works with the HPE files. I think it works with the HPD files used by your favorites lists but I could be wrong about that.
Thanks for this info. I can't remember using ProScan for importing files before. At least not with the x36 or newer models.ProScan can import hpd (Favorites) & hpe Files.
