HT-1000 Antenna Question
El Paso, TX
#1
Can anyone tell me what adapter I would need to use a PL-259 connector on my Motorola HT-1000's or where I can find an external antenna I can plug into these radios? I appreciate any help.
Chicagoland
#2
You'd need an SMA-F to PL-259. You'll probably find that you need an SMA-F to BNC, then step up the BNC to a PL-259 from there.
eBay is your friend on this one. They can be had for under $10.
