GUNUT
Hello,
I have a situation that does not seem to get any better, it involves Motorola HT 1250 portables.
Here are the details:
1 the freq band is 150 MHZ
2 have 3 Astro tac receivers all which are in the specs as far as their sens. and the antennas look good as far as SWR.
3 these are part of a voting system that uses a SNV 12 voter, which appears to be voting right, levels set per book.
4 when the officers call in they are complaing that they sound scratchy, like weak sig.
5 when I have the officers take off the lapel mics, ones without antenna just standard, they sound good, just like th body is desensing the RF along with the Kevlar vest.
6 I called Motot about the lapel mic issue but they have no record anywhere of this happening, even though you can see it happen with a spectrum analyzer.
7 they want to use the lapel mics but without more tac receivers, I cannot make it work well, only without the lapel mics. The lapel mics with the antenna on top are too long and do not work well.I know other places use lapel mics, but maybe it is 450-800 MHZ and not as funny about the human body/ vest arraingment.
Any body else have this problems with the lapel mics sucking?
