HT-1250LS question
N1DDC
The P25mosphere
#1
Good day all,
A few days ago I purchased an HT-1250LS UHF handheld, was excited to get it, hooked it up to CPS & much to my dismay discovered that it doesn't do MDC-1200 (which I rely on heavily for Radio ID's and repeater functions & such...), it will do MDC-1200 in LTR Trunking mode but not Conventional (THAT makes zero sense to me whatsoever!), SO, my question is... Is there ANY way to get MDC-1200 working in this radio without having to sell it & deal with the headache of getting a new one? Is there some sorta Hex Edit in CPS that will enable the MDC Signaling drop-down menu for Conventional Personalities, or some sorta mod I can do? If the radio does MDC for Trunking it means it has the capability so I would think there is a way to do it in Conventional mode... I would appreciate any comments/suggestions, and thank you in advance! :)
David
