Ht1000 no volume volume control
Pottstown pa
Radio programs fine and works fine. Radio worked before it was cleaned with mild soap and water. Now I can no longer turn the volume up or down. But the radio works in every other aspect. It transmits and receives perfect. I can change channels. The water was not directly applied but brushed with a toothbrush as I have done with all my other radios. I don’t want to fry the rest of the radio. Where should I start with diagnosing what failed.
MTS2000des
5B2_BEE00 Czar
Put the portable in test mode. Spinning the volume pot should result in several "beeps" from low to high while rotating. If not, then you need to replace the volume pot, or the front cover flex assembly, with a new one.
MTS2000des
5B2_BEE00 Czar
Very possible some liquid got into your control while cleaning. It dried out and now it works, with these being 3 decades old the O-rings are no doubt drying/cracking and factory applied lubricant is probably all gone or dried up so easy for water to get into. FWIW these were never water tight from the factory barely obtaining an IP55 rating for driven rain. Paper speaker cones get soaked after the felt is wet.
