HT1000 Questions
landonjensen
Area C
I was looking at a manuel online about HT1000 on the RSS. Im trying to learn all the lingo. :p Just a few questions on what the following things are:
-Volume Set Tone ?
-Man down Pre Alert? I know what the man down alert is, but Pre Alert?
-Alert Volume for TX and RX?
-PTT Tx Inhibit Alert?
-PTT Sidetone?
-Emergency Sidetone
Under MDC Confirguration, what is
Radio Check?
Repeater Ack Alert?
Thanks to those that respond.
Pimpala03
Northern Louisiana
PTT Sidetown is part of what makes the "Talk permit tone" sound when you key up. you press the PTT, and it makes a (approx) 1 second tone then you start talking. During this 1 second tone your ANI (MDC-1200) information is sent if your radio is configured to do so.
Another nice thing is if you set the battery alert volumes to "volume knob" the sound of this "TPT" can be adjusted with your volume knob.
Without the software in front of me, I can't answer the rest.
K8TEK
Banned
Ohio
-Volume Set Tone ?
-PTT Sidetone?
-Emergency Sidetone
Radio Check?
Repeater Ack Alert?
Where is this manual located at online? I need a copy, please forward me the link where it is located here!
K8TEK
Banned
Ohio
landonjensen
Area C
Email sent!
Any more help on my question is greatly appreciated. Thanks again.
LJ
BigLebowski
Piedmont NC
-Volume Set Tone ?
-PTT Sidetone?
-Emergency Sidetone
Radio Check?
Repeater Ack Alert?
Volume Set Tone: You can program a button so that when you push it, it emits a tone to help you select a comfortable volume.
PTT TX Inhibit Alert: Emits a tone when you press PTT and transmit is not allowed, either because the channel is RX-only or busy.
PTT Sidetone: Emits a tone while you are transmitting Data (such as MDC1200 or GE*STAR) so that you don't try to talk over the data.
Emergency Sidetone: Emits a tone while an emergency signal is being sent so that you don't try to talk over it.
Radio Check: Lets others page your radio, and your radio will respond with an acknowlege. Basically others can see if your radio is turned on.
Repeater Ack Alert: I've never used this feature, so I don't know.
