HT1000 Weird Squelch Noise?
Foresthill, CA
#1
On a single channel on my older UHF (450-520) HT1000 there's an intermittent noise, similar to the sound of the squelch opening. The noise occurs about once every two seconds, and lasts for about one second. Upon comparing the noise to the actual squelch opening, it sounds softer. The sound does not cover TX or RX- only happens when there is no activity on the channel. Is anyone familiar with this at all? It's not a big deal, but I am curious as to whether it's an error or something. Thanks!
So Cali
#2
Did you actually check the squelch settings in the Alignment section. A service monitor is usually required.
May be a narrowband channel, and the squelch settings may be incorrect.
Foresthill, CA
#4
I don't have CPS, so I can't answer some of your questions, however, I don't think it's a narrowband channel because I can monitor all of the activity without any (apparent) interruption.
KE5OTC
#5
I have the same problem on my uhf maxtrac.... being caused by my wifi router
Sent from my DROID RAZR using Tapatalk 2
Duster
CA/NV/KS/NE DB Admin
Placer County, California
#6
Sounds like a data burst...I hear that sort of thing on LTR's, and also on a couple conventional channels around here that are used to activate/monitor landscape and public works systems (sprinklers, etc).
