HT1250/750 USB cable driver Disc help....
GBLOCK
The Sunshine State
Does anyone have a driver disc for a USB cable for the HT750/1250 radios for either Windows XP or Windows 7?
When I try to read/write the radio on my new computer I get "Couldn't open port. Check whether Device/RIB are powered on or not, and the device to RIB, and the RIB to PC connection is ok." Radio is powered on and all connections are secured. Tried all available ports in drop down window in CPS with same message everytime.
Thanks in advance for your help....
cabletech
Puget Sound
Where did you get the USB cable? It should have come with a driver disk. You can also go to google and lookup proflic for drivers that should work.
GBLOCK
The Sunshine State
Unknown model of the programming cable. Appears to be unmarked, just says made in China. Original driver disc unfounded at this time. If anyone has a link or if possibly can email a driver in a zip file to try, I will try to give that a shot.....thanks.
