ht1250 cps error
streeetsno
ct
tried reading a ht 1250 limited pad today, got a "codeplug version not supported by cps" error followed by "unable to create layout for modelindex 1, version index -1, cpstdversion 03.00".
any help with trying to read.............
KJ6HCB
San Luis Obispo, CA
Yup - the radio has been programmed with a version of CPS newer than what you are using. Unfortunately, many older versions are not backwards compatible.... but I believe the newest series of radios are.
RRSINC
Woburn, MA
According to MOL the latest is R06.12.04 which came out in Sept.
