HT1250 front button problem
NJC4850
NJ
I was recently given two Motorola vhf 1250 radios by a former coworker who accepted a new job out of the country. one yellow and one black, but they are both 1250s. While attempting to program the yellow radio, I kept experiencing problems because the P2 and button above p1 (up one level) are not responding. at all.
I am pretty sure I am programming them properly, because when I copied the programming cfg file to the black radio, the buttons work properly.
Does anyone know how or why to fix this? is it an easy hardware fix, or do I need to take it to a motorola dealer for repair?
any help would be greatly appreciated.
mformby
East Texas
Print out the programming if you can and compare each one to the other. If the programming is identical then it is probably the button (worn or dirty) contact.
InlandEmpire
Riverside County California
Does P2 and button above P1 beep (low tone) when you push them, or are they silent?
Low tone= programming isn't set up to use those buttons.
Silent= probably dirty contact- open, re-seat pad after a little cleaning; clean and reset ribbon contacts.
