HT1250 Qick-Call II sample tone issue
Eaton90
Hi everyone!
I programmed my HT1250 to have 3 different single-tone Quick-Call II signals available for transmitting. But when I try to send any of this calls the radio beeps the same alert tone - no matter what one I want to transmit. It is very annoying and inconvenient - I'm not aware if I sent right or wrong Qick-Call. I want my radio to sound exactly the same as the target radio will receive my call. How can it be done?
The only thing I found in the codeplug settings is disabling the alert tone at all - but that's not what I want.
Please help me with it!
Thanks in advance!
TheManBornWithin
Ocean County, NJ
I just checked with my HT1250. Regardless of which set of tones I send, I get one long beep. As long as you have the right one selected on screen (I'm assuming that you are going to Radio Call -> Selective Call or Call Alert) you're sending the right one.
Hope this helps!
EDIT
I thought I had a codeplug on my laptop, but it appears I don't. I'll check a codeplug tonight to see if there is an option to select to let you can hear what is being sent.
Eaton90
I would be more than grateful to you if you find out how to make the radio sound the actual call tone. It seems to be strange that Motorolas can't do it since Kenwood TK-3180 can, as far as I know...
