HT1550•XLS MDC Issue
Zsneese
Martin, Georgia
#1
I have a ht1550 and it transmits MDC just fine but it will not decode. Where in the CPS can I turn this option on?
Those views reflected here by me do not reflect those of my department.
SteveC0625
Northville, NY (Fulton County)
#2
In each personality where you want to decode MDC, , on the Signaling tab, you have to select your Receive MDC system from the drop down.
If you have it transmitting the proper MDC code, you were already in the Signaling tab to turn on MDC for transmit. Same place, enable Rx MDC.
