jrothwell
I've HEX edited the dll and the CPS so I am able to enter the minimum and maximum frequency range and not have the CPS complain that's it's invalid. I read the radio and changed the values, then saved it. I opened the saved codeplug and entered the OOB frequency into a personality, the CPS accepts it. When I try to write to the radio, I get an error message stating that the archive has a frequency that is outside the bounds of the target radio's frequency range and it will not write. If I try to write to the radio after only changing the min and max frequency range, but not enter an OOB frequency, I accept the UPGRADE warning message, and the radio acts as it's received the programming and accepted it, same with the CPS.
Any ideas as to why I'm getting this error message? I should just be getting the UPGRADE warning message and then the write should be successful.
Thanks,
Jason
Thanks,
Jason
