ht750 programming problem
nmartin29
Geneva NY
im attempting to read an ht750 and I keep getting an error that says the cps version is not supported. I tried to defeat this by sending a previously written program from my computer to the radio, it seemed to work but it asked for a password. Any ideas on how to defeat the password?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Are you using Professional Series CPS HVN9025? If you have any other CPS, it won't work at all on your HT750.
What version of the Professional Series CPS are you using? If your version is older than the version that last programmed the radio, you won't be able to program it. The rule of thumb is always that the radio has to be reprogrammed with the same version or higher.
