Ed6698
I have not owned a new Uniden scanner in a long time. I finally decided I wanted a base scanner capable of good P25 simulcast performance, been using a Unication G4 with the Trunking Free Scan FW with good results. I stayed away from the Uniden SDS200 due to some of the complaints of the hum issue lottery. I purchased the SDS200 from Bearcat Warehouse last week and everything seemed good, I could hear a little hum from the unit with the internal speaker, but nothing totally bothersome. However I always use external speakers on my base scanners. Once I hooked up the external speaker the hum was terrible, tried multiple different speakers, that hum was totally unacceptable. I researched a while back on the hum fix before even buying it, plus I always used to be handy with electronics back when I was younger. I took it apart today following all the stuff I have read on here in the past few days. I did the @StaticDischarge fix and now the SDS200 sounds great on the external speaker, no more hum at all. If I could not have done the repair I would have probably returned it. So thanks to all on here that posted all the good information including the photos for opening the radio up and the actual fix that works. I really do like this SDS200.
