Hummer install
NECW4
New Haven,CT
Anyone have pics or know where i can get a console for a hummer H2?Bin looking and cant find anything. Thanks
datainmotion
Colorado
If you are referring to a 3rd party console for radios, etc., you may be out of luck. Most console manufacturers made consoles for popular public safety vehicles only and Hummers weren't one of them. You may have to find a close match and work around the shifter.
Good luck.
Alliance01TX
DFW Texas
H2 Console
Howdy
You might also consider either getting a metal or wood 'Fab Shop" to build for purpose console and then you would have options on the 'finish' that truly be a 'custom' fit. Yellow pages or on-line areas and also some RV shops have contacts to various fab-shops too...
1- Stainless Steel (might be a bit hot in summer and bright, unless a satin finish..)
2- Nice Cherry Wood or Walnut
3- Stainless with a "powder coat' color that suits....in a 'flat finish' to reduce reflection of sunlight....
4- Leather or Fabric cover.....to match interior, etc...
The 'custom' job would also give you 'options' that the stock-boxes mostly do-not have, such as extra storage and methods to 'cover-conceal' the radios when you are away from the vechical....
With the so-called 'stock' consoles running at the high-end up wards of $600, I would think you could get a great deal via local fabrication shop / upholstery shop(s)....it look look a lot better than the 'black-metal-boxes' that are over-priced in my opinion....
Let us know what you get....
Thx
Bill
NECW4
New Haven,CT
Thanks for all the help guys. I went to look at hummers the other day and decided i didn't want one. They are just too big and there is nowhere to put radios. I might be going with a Tahoe.
b7spectra
EMS Dispatcher
Cobb County, GA
zz0468
Banned
You may want to look at a 4Runner. Some of the recent models have a slide out tray in the rear that's perfect for hiding radios underneath.
firedawg0069
Moberly Missouri
Howdy
Thx
Bill
alliance i had the same situation with my 1989 S10 blazer. While there are plenty of console on the market for blazers, there are not any for mine so i made one myself. It is nothing fancy, made it from cherry veneer mdf and birch plywood that i had around the house. there are pictures of it in the "pictures of my mobile setup"fourm under the thread "1989 S10 console
paramedszaf
Kingston, Pa - Luzerne Co.
Tahoe and Silverado (same interor body style / bolts ect.) HIGHLY recommend something without that goofy full console. Go with the open hump, will make your choices from a wider selection without having to move more than that "20" of a 40/20/40 seat config.
wcr20
Volusia Co, FL
custom console
I made one for my '90 suburban out of 1/4" dark smoke plexiglass. Used sheets of corrugated to rough out the sides and then had the Plexi cut to match. Used 1 stock U bracket to attach the stack to the front of the stock center console, everything else just bolted thru holes drilled in the plexi using the stock screws that came with each radio.
