Hytera PD682
robertpearsall
Edison, NJ
Admin sorry if this is the wrong form if so please move.
I have a Hytera PD682 with the XPT Trunking option, my question is can this radio do connect plus if so how do I go about updating this radio to this feature.
Thank you in advance.
Bob
RayAir
Bob
No.
Only certain MotoTRBO radios can work on a connect plus system.
However, if you only want to scan (monitor) a connect plus system, Hytera makes it a bit easier to do.
What are you trying to do?
robertpearsall
Edison, NJ
I want to listen to one talk group on the one voice system but it is multi sites the use for this talk group
RayAir
The best you can do is pick a site, then program in the site frequencies as pseudo Trunk channels.
This way you only have to program them in once, instead of once for each time slot.
However, leave the control channel slot out. It's usually TS:1.
You'll have to assign a group rx list to each channel with the TG you're trying to monitor.
I wouldn't expect great results. You would be better off with a DMR scanner because the Hytera cannot follow the trunking.
