I-70 From St. Louis to Kansas City
nbarco
Grovetown, GA
Does anyone have the site list and talk group info for a cross-state drive via I-70?
nbarco
Grovetown, GA
So if I put in the control channel for the sites closest to I-70 and the Dispatch talk-groups it should work?
nbarco
Grovetown, GA
By the way, on the way back I will take I-44 since I have to stop in the Fort Leonard Wood area. You have those?
frazpo
SW Mo
Yes, If your on a Uniden just scan in search mode. The sites are listed on the drop pins. I would make a list of the sites along I70. Use software and load the associated sites. As far as troops go just load Troop A,F,C talkgroups.
Troops D,I,C for I44
