I am stumped
HoDo
Baltimore, Maryland
I tried everything, read, re-read, tried again...
I have a PSR-800 as of 2 hours ago. Last night before I got the radio I bought a 8GB card and downloaded the GRE EZ program on my computer. I went thru the library and added Maryland city, msp, county in scanlist 1. So today I get the 800. I go thru the library on the unit and pick, Maryland, Baltimore County, then just police. I check off everything I want. I then go back, import and select scanlist 1.
My problem is I don't just have Baltimore County police in there, I still have the city and msp. How do I clear the whole scanlist 1 and start fresh or should it overwrite the whole scanlist when I import it or does it just add to the list and not completely overwrite?
Like I said I have tried everything, even reading the manual line by line.
**UPDATE**
I did a new search and made a scanlist 2 for my work area and it works perfect, but all the areas are still in scanlist 1...
HoDo
Baltimore, Maryland
okay, called the guy Shiro from GRE. He told me to uninstall the software on my laptop. I did that. I reinstalled off the cd my 800 came with today. Problem is when I install the software it still shows 200 objects in scanlist 1. It doesnt start fresh with all zero everything. My scanner is correct with scanlist 1 and 2. But if I try to copy from my scanner to the laptop it is not overwriting the scanlists. Any help guys...
Bronson24
Frostproof,FL
GRE will walk you through EVERYTHING just give them a call back...they have the best Customer support EVER!
