Also a little reminder on NXDN and DMR Public Safety, before you go buying an NXDN HT, or Mobile, you really should run DSD+ using an tapped scanner to see if there is encryption enabled on the Public Safety users. Not sure on Kenwood, or iCom, but Motorola is now making sure encryption is on as a standard part of the package for public safety users when they buy new radios/systems. It is up to each agency to decide to turn this feature off. Encryption is no longer an added cost, it is standard and free as part of the programming templates. So again, I highly advise checking with DSD+ and a tapped scanner. (Many of the newer scanners feature a feed out from the tap point/s to an "line out" PC/IF type port, so all you'd need is an mono to mono audio "patch cord" to run from this to your computer's mic/line in jack. Some users have great success with mic in, others it just won't work right unless its the line in.
