dragon_slayer79
I'm wanting to purchase a new mobile antenna because my current one is really starting to show it's age and it just doesn't seem to be able to pull in as much as it used to. I'm currently using a RS 20-032 and have been for about 8-9 years now (the same one). I have been reading the forums for weeks now with others asking about antenna suggestions and it doesn't seem ANYONE can agree about anything. There HAS to be a difference in performance or something between a $20 all band antenna and a $100+ all band. If there's no, and I use the term loosely "BEST" antenna then why isn't everyone running a $20 paper weight?
The bands I listen to 90% of the time is 150-160 & 450-460. I am a HAM and I do listen to area repeaters from time to time, but not constantly. Those frequencies are 53.03-1285.5. For the HAM stuff 90% of that is in the 140's and 440's. I was thinking about the Spectra, but I've read both comments "it a perfect antenna" and "it's junk don't waste your money" and everything in between. I'm on a tight budget and don't want to blow $100 on an antenna that will be worse than what I already have or doesn't perform any better than a $30 one. I'm not really too worried about it having to be very low profile, an antenna on my vehicle doesn't bother me. Obviously the one I'm using is a mag mount, but have been considering using a NMO mount. (hole type). Does this mount offer any advantages over a mag mount as far as being able to pick up signal better since it will be grounded to the vehicle? Or other advantages besides not being knocked off by a tree branch or something.
Other info you probably will want to know...
Scanner: Uniden BCT15X
Antenna: RS 20-032
Cable: Stock cable with BNC that's pre-attached to the antenna
Vehicle: '92 Saturn SL1
Oh I do listen to 800MHz when I can. Not a huge deal though. In my home county there is only very few 800's so I don't mess with them too much at this time.
Any suggestions and/or links to products that you might be able to provide will be greatly appreciated. Thanks for your help and time.
Antenna: RS 20-032
