I need help programming Verdugo fire red 1 on my WS1040 , its P25 phase 1
FirePhoto27
XLC
I have tried doing this on my scanner as a conventional, it dosent pick up all the time, and there is encryption sometimes too. I have a whistler WS1040
FirePhoto27
XLC
Oh because sometimes it picks it up and sometimes it picks up other channels that have encryption
Spitfire8520
Might be slightly less clueless! =)
Colorado
You will need to learn how to program a trunked radio system (TSYS) in the scanner. Programming a trunked system like a conventional frequency will lead you to hear everything on the radio system because the scanner has been setup in a way that it cannot select a talkgroup to monitor. Are you programming your scanner by hand or with some sort of software?
tvengr
Well Known Member
Baltimore County, MD
What site on the Interagency Communications Interoperability (ICI) system is closest to you? What programming software are you using?
cmdrwill
So Cali
Red 1 is also on VHF 154.37 and that used to be on St Katherine North East of the Rose Bowl.
Ronaldski
MI DB Admin
Bay City MI
FirePhoto27
XLC
I am in Glendale, Ca. I know how to program a talkgroup, I just dont know which frequencies
FirePhoto27
XLC
I program on the scanner and sometimes Win500
glradio
OES Region 1 Area C
Verdugo always uses the Burbank, Glendale, and Montebello cells. As for monitoring, Glendale is the best for most of L.A., and Montebello is best for the southeast area.
tvengr
Well Known Member
If you are in Glendale, I will use that as the site. I usually program using ARC500 and I have Win500 also. I will create a file for you using ARC500, send it to my trusty old Pro-197, and read it into Win500 to create a file that you can use..
tvengr
Well Known Member
I have completed the file. You have 6 scan lists:
1. Verdugo Fire
2. Glendale Fire
3. Glendale PD
4. Comm College PD
5. Emergency Ops
6. Interop
Save the zipped file to your computer and extract. Open the extracted file with Win500 and upload to your scanner.
  • Glendale CA.zip
FirePhoto27
XLC
Thank you but, it that that type of file is not supported.
