I need help setting up BCD996XT online
freightguy
Meriden CT 06450
Running RadioFeed with Serial Port Monitor on a BCD996XT.
I can see the data going through the serial port, but the sound card is still connected. Is it normal for the feed to go through the sound card from the serial port? Or did I miss a setting somewhere?
Mike
rdale
Lansing, MI
I'm confused, but maybe since I've not used RadioFeed but ScannerCast.
In any case, the sound comes out of your speaker and goes to your soundcard. It's not related to your serial post. Where are you plugging the audio from the radio into?
freightguy
Meriden CT 06450
When I have it connected through the phone jack and use the audio card, it works fine.
Maybe I'm the confused one...I though that the unit would broadcast through the serial port, and send tags and information, w/o using the audio card, through com1...?
rdale
Lansing, MI
No, the serial port is just for the tags. Audio needs the sound card.
