I4R05K01.DSP Code
rmiles
Bel Air, MD
#1
Has anyone else noticed this? I loaded I4R05K01.DSP into an AEGIS enabled LPE-200 (mine, not GILMOORES) Once I loaded that code, I could no longer hear AEGIS transmitted from the LPE on another AEGIS radio. I could hear my M-RK's fine on my LPE with I4R05K01.DSP loaded, but when I transmitted voice from the LPE, I could not hear it decode on my M-RK.
Another AEGIS LPE I had with an older code (I4R05H01.DSP), which I previously had no problems hearing on my M-RK, suffered the same problem after I "upgraded" it to I4R05K01.DSP. I've since had to downgrade all my LPE's to I4R05H01.DSP. Incidentally, the both AGEIS DSP coded sound similar on a scanner, so I know it was transmitting "some sort" of AEGIS DV, but something is amiss with that code. Perhaps I have a corrupted I4R05K01.DSP file?
#2
This is a problem Macom knows about. For analog and Provoice radios the current flash/DSP combo is P1R17B03 and I4R05K01. As you discovered it doesn't work on Aegis.
For Aegis use P1R16C00/I4R05G01 on C56 equipped LPE-200
the same also applies to the J700p of the KRD flavor. For them use S1R05C03/I4R05H01
rmiles
Bel Air, MD
#3
I don't have either of these code sets. Anyone out there have a copy?
