IC-2200H Data Out and Unitrunker
scanningdude
I had originally posted this in the Trunking Control Channel Decoding forum but they suggested I ask in this one as well.....
Can anyone confirm if the ICOM IC-2200H will work with Unitrunker? According to the manual it does have a data output jack, from what I have read so far as long as it has that it should be a matter of hooking it up to a computer, program the control channel (monitoring a Motorola Type II SmartZone by the way) and turn on the 9600bps data output and a way it goes. It also must be able to receive on 142.xxxxx and possibility 143.xxxxx MHz which according to the specs it is in that receive rage.
If I am wrong can anyone recommend a model that would allow this capability/features.
I would rather not try and add a tap to a old scanner I spent some time trying that before but was unsuccessful.
Mike
