IC-5020
chilledinpa
Good evening, I have the IC-5020 Vhf and is MDC 1200 compatible, I have it programmed after a lot of frustration with the software but I am having trouble with the Data bursts that can be sent pre or post audio transmission, my ID is being transmitted but the audible data burst is not working. I must be missing something in the software. I have spent hours trying to find what I am missing. If anyone has any idea what I am missing in the software it would greatly be appreciated. I have no problems with motos Cps but this Icom has thrown me a loop.
12dbsinad
What exactly do you mean your ID is being transmitted but the audible data burst is not working? Are you sending MDC to another radio that is decoding it but not hearing the data burst?
chilledinpa
Thanks for you reply. When I key up my Icom for a transmission the data burst is not being heard, only my 4 letter ID is being sent and displayed on another radio that is receiving my transmission. I use mototurbo's portables and have no issues with the MDC burst sound being sent. My Icom is my mobile.
12dbsinad
You're probably talking about the "key up tone" you hear on your Motorola. That's not actually the MDC data burst and your Icom does not have that key up tone feature. You should be able to hear your MDC burst on the receiving radio as long as there is no DOS set on said radio.
chilledinpa
I finally found it>>>>
In Memory Channel:
-Set Log-In/Out to L-OFF
-Set Signalling to 5T - 5T - 5T
-Set 5Tone Signaling | Form to EIA
-Set 5Tone Signaling | ID to 28
-Do this for every channel line you want a beep.
On the left bar, open 5Tone | TX Code CH
-In TX Code for Line 28 put in 3 (you only want a single beep, not five tones)
That will add a single EIA Digit "3" blip at 1,023Hz to the end of every PTT on that channel.
