IC-621-2-TR display problem ?
merlin
DN32su
Picked up a couple toys, the IC-621-2-TR. There is no display or backlight and wondered is anyone has run into this and the fix.
I ordered the service manual, but it will be a couple weeks. Also noted a document mentioning no display issues.
These are on my front burner and want to get them back together to clear my bench.
73s
12dbsinad
Take the front cap off and check for liquid intrusion. Check for things that look "green". It's fairly typical to have the display fail due to liquid.
jeepsandradios
East of the Mississippi
As said pop display off and check connections. I have one that has no display. It was pretty corroded. Cleaned up and still nothing. I use it on my APRS anyway so didn't mess much more with it.
merlin
DN32su
No sign of internal damage but winging a troubleshoot, what should be 5 V is more like 3.2 so something awry with the power circuits. Pretty simple radio, shouldn't be a hard fix. Might have this running before my manual gets here.
>found the 8 V regulator but I think it is switched off for no signal from the brain.
Pressing the power button, there is a bit of current(35Ma) so not hopeless.
merlin
DN32su
WOW, Not far off, the main power switch transistor is bad. Bypass with power on button, the radio works.
Pulled the device and a bad bulge.
The display I can't make out, either a system name 'east' or something like 'test'. I will know when I program this.
