IC-F221 Programming help
KF7OQQ
Under Your Bed
I bought a IC-f221 and going to use it for GMRS. After programming it the squelch sounds like it is stuck open on all the channels. Is there a setting somewhere that i am missing? I want to program with no PL's. I am planning on using it for our Jeep group. When i bought it and plugged it in it wasn't acting like that with the frequency that were programmed but it had a trunk system programmed into it. Any help would be great!
KF7OQQ
Under Your Bed
Sorry it might not of been a trunking system but it was set up really weird. thanks for the info on the squelch values. is it the higher the number the stronger the signal needs to be to open the squelch?
Thanks again for the help.
JSTweedie
East Hartford CT
How did you end up programming your F221? I have an f221s, and I'm using cs- F100 software to try to program it but I can't get my laptop to communicate with the transceiver.
ramal121
Lots and lots of watts
Calif Whine Country
This always threw me. Different software. For a F221S you need CS-F100S.
