IC-F22sr 446 handheld
UK
#1
Hi
Is it possible to change the frequencies pre-programmed into these radios, or change remove the tones, PL, Ctss etc again pre-programmed into these radio, if software is required what software version is it ?.
Thanks in advance
David
