IC-F5023H Loose memory
#1
I need help please.
IC-F5023H Loose memory while switched on and power is cut. It sound two beeps and then show Clone NG on the screen.
Vancouver BC
#2
While I have not seen that on that model, on another ICOM product it had to go back to Icom under warranty
hopefully yours came from legit dealer and they can take care of warranty for you. how old is your radio and whom programmed it ?
#4
What is the maximum supply voltage for these Icom radio's and will 14.5volt peak cause any damage to the radio?
Vancouver BC
#5
if you have an overvoltage issue the display will show OVERVOLTAGE, peak should be ok radio requires 13.8 volts, that radio is under warranty it will have to go back for re-programming or replacement under warranty
#6
This radio is used as a base station and the supply is a 105Ah battery connected to a smart charger. I don't believe the voltage will exceed 14 .5 volt otherwise the battery will sureley overheat. I received a confirmation from Icom UK specifying the maximum voltage to be 16 volt.
