Ic-t90a question
Bayonne-Bob
Only batteries to be used on the T90A is original 1300 mah
as well as one i found from a long island battery dealer in hicksville ny
( W&W i think) that is 1400 mah
Icom_Junkie
Earth
IC-T90a .... Battery Pack
The T90a battery pack has to be a Li-Ion type to TX at 5W.
I've read if you use anything else, the TX power is 1/4 W max.
Then again, .... my fancy factory Icom Hi-dollar HT Li-Ion pack has not gone belly-up yet.
kc2aqa
Baker845 - were you able to get an MB-98 belt clip to work on the IC-T90A? I'm in a similar situation...
WayneH
Forums Veteran
Super Moderator
Your master site
Moved to the Amateur Equipment forum. The IC-T90A is not marketed as an ICOM receiver.
