Paco-Jerte
You Member, Member!
Hey guy first and foremost hope everyone taking all precautions and staying safe.
Now, recently acquired once again a Uniden BC796D (should of never sold mine couple of years ago. And decided to reload an old .mem from 2015 that worked fine on my 796D back then.
Loaded it yesterday and wont do ID SEARCH by pressing the DOT and or holding TRUNK down.
Made a new file from RR database using ARC250PRO and still wont work. doing the same as stated above.
This is how I have the settings.
Trunk Type: MOT TYPE 2 - UHF
icall - ON
Status bit - ON
End code - Detect
Base Config 1
Frequency - 0480.5000
Step - 012.50
Offset CH - 380
Base Config 2
Frequency - 0470.0125
Step - 012.50
Offset CH - 380
Base Config 3
Frequency - 0481.5500
Step - 012.50
Offset CH - 580
Activity ID - Checked
Would appreciate info anyone that has the BC796 or BC296D working fine with ICI P25 in advance. Thanks
Interagency Communications Interoperability (ICI) Trunking System, Los Angeles County, California
Interagency Communications Interoperability (ICI) Trunking System Profile
www.radioreference.com
icall - ON
Status bit - ON
End code - Detect
Base Config 1
Step - 012.50
Offset CH - 380
Base Config 2
Step - 012.50
Offset CH - 380
Base Config 3
Step - 012.50
Offset CH - 580
