Icom 208h mic extension cable
thelongfellow
I know I can make a mic extension cable using everyday cat5, I don't know what the wire configuration needs to be? Can someone help me with this?
Thanks!
Jonathan
K5TLF
N0IU
Wentzville, Missouri
I don't understand what sort of configuration information you need? I would imagine it would just be straight through since you want the connector at the end of the extension to be exactly the same as the connector at the end of the mic cable.
thelongfellow
Sorry that I was not clear. I guess what I want to know is, will a standard network cable work with a RJ45 coupler?
W4TF
FL
I'm been using a regular LAN type cable from Radio Shack for years as an "extension cord" for my 208h mobile with no problems at all.
73,
Singh, AJ4VS
