For RX only, a 3 Amp power supply would suffice as previously noted, but some older and new models may provide noise. This could be problematic with your interest.
As this thread has adjusted beyond RX power only:
- I have an Astron RS-35A and it provides plenty of power, but I transmit as well as have other items getting their power from it while I transmit. I run a pigtail wire from it into an Anderson Powerpole multi-strip fused outlet.
- I have the Powerwerx SS-30DV and I quite like it with the power pole connectors on front. Still, I forget where or if on all of the 6 meter band, but it does provide noise there. Not enough to keep me from using it though except on 6m. I believe I discussed this before here on RR and someone else does not have that noise problem on 6 meters using the SS-30DV. This leads me to...
As to your area of interest, noise caused by things in your home or relatively near the antenna may cause more hash than a noisy power supply and interfere with your endeavor. A proper RF choke near the antenna feed point and maybe at the radio might be the biggest help. I use one at my antenna feed point with an Off Center Fed antenna and it reduced the noise around 2 dB. An additional RF choke at the radio did not help, but everyone's situation is different. I also have MW broadcast stations nearby, so I use a high pass filter which attenuates RF below 1.8 MHz.
I also agree with Hit_Factor, if I was only going to receive I would option for the Icom 8600. You pay more but get more.
